Discussion topic: Single artillery cable to set Q box
This message was authored by: Ipad..
I need a cable that comes out of sky q into a single ariel port on wall. There is a large communal dish on my estate why allows sky to work. Anyone's know that that cable is?
Re: Single artillery cable to set Q box
hi @Ipad..
You just need to search for Satellite Cable Fly lead
The come with 2 'F' connectors on each end and can be obtained in various lengths
Hi @Ipad..   Just in case you are not aware, the LNB type will need to be changed in the hidden settings for the single feed.
This message was authored by: Godfrey
@Ipad..  to configure a Sky Q receiver to use Single Cable Router (SCR) LNB mode;
Press Home
Scroll down to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
You should now have the engineer's menu displayed
Change the LNB type from the 'default' Wideband option to SCR
After changing the LNB mode, remove mains power from your SKY Q box, and then restart it to allow your Sky Q receiver to re-configure itself to now use a communal Single Cable Router as its satellite transponder signal source.
Godfrey.
This message was authored by: Me134
Perhaps I'm missing the point here but wouldn't the (presumably) existing shotgun cable work, just attaching one of the ends to the single 'aeriel socket' (unless that turns out to be a terrestrial aerial as I initially thought)?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
My thoughts (& hence my reply)  were just that the cable was lost or  broken and thus just needed replacing.
Avatar for Ipad..
the original cable came out of the dish which I left hence I need to replace
This message was authored by: DaveDrizen
Can you not find out who  owned or maintain and provides the service for  that communal dish system. They should have people like Sky do  that  connect the consumer to there system and set up your Sky box to work with there system, they are  not usualy user self install. Also would have thought such communal dish systems like cable companies are not usually free and you probably have to pay monthly or yearly fee to use it to cover things like  maintenance cost ect on top of your  Sky subscription.
