Discussion topic: Mini sky box problems
This message was authored by: funkydorey
My mini sky box needs rebooted quite regularly, upto 4 times per week,
Re: Mini sky box problems
Hi @funkydorey
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
