Discussion topic: Signal problems
Message posted on 31 May 2024 05:31 PM
Signal problems
Losing signal, picture scrambled
message saying we are having technical problems
Message posted on 31 May 2024 05:40 PM
Re: Signal problems
@Stuart661 Have you tried rebooting your main Q box ie
Message posted on 31 May 2024 05:53 PM
Re: Signal problems
Hi @Stuart661
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
