Discussion topic: Signal problems
This message was authored by: Stuart661
Signal problems
Losing signal, picture scrambled
message saying we are having technical problems
Re: Signal problems
@Stuart661 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Signal problems
Hi @Stuart661
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
