Discussion topic: Signal issue with Sky mini box
Message posted on 27 Jun 2023 11:47 AM
Hi all,
I have a Mini Box and the signal keeps freezing every few seconds. It's actually been like this for several months now but it's taken me a while to act on it. Has anyone experienced similar issues? I can switch it on fine but the signal keeps breaking up and the picture freezes. If I watch something on record, I'm unable to fast forward as the picture gets stuck on the current time.
I think I probably need a new box as the signal on my main Sky Q box is fine.
Message posted on 27 Jun 2023 11:55 AM
Re: Signal issue with Sky mini box
@bob21493 wrote:
Hi all,
Hi @bob21493
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 27 Jun 2023 12:01 PM
@bob21493 wrote:
Hi all,
hi @bob21493
There are a few things that may be affecting the signal on the mini box - it is not that likely that it is faulty.
I am guessing it is connected via wifi rather than ethernet.
If your home wifi is not SKY then you need to be aware it does not use your home wifi but instead a wifi signal generated by the main box.
The mini box depends on the main box for virtually everthing so the first this I would sugget is a power down restart of the main box:
So the first thing is to restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down on the mini box
After that maybe consider seeing if anything could be interfering with the wifi signal to it (I believe Landline wirelsss phones can be a cause of some interference for example).
When I first got my mini box installed I had regular problems in the evenings - moving the mini box by about a foot & turning off wifi on a AV Amp it was very near cured my problems
