Discussion topic: Connectivity to TV from router
Message posted on 27 Jun 2023 12:01 PM
Connectivity problem with WI FI from router to TV suddenly appeared on Sunday. The sky internet is working on everything else. Tried going into the settings following instructions and pressing the WPS button with no success showing error MR 106. Everything has been unplugged and rebooted still no success.
Message posted on 27 Jun 2023 12:08 PM
Re: Connectivity to TV from router
Hi @AlanPat123
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
