Discussion topic: Shift dish
Message posted on 04 Nov 2025 03:56 PM
Shift dish
Need to shift the dish to a new location as the present position is being demolished.
Message posted on 04 Nov 2025 03:58 PM
Re: Shift dish
You will need to call Sky to discuss and providing there's another suitable spot for it they'll be a charge.
Message posted on 04 Nov 2025 05:58 PM
Re: Shift dish
Or employ (and pay) a local independent installer, which might be rather faster than waiting for Sky availablity.
Message posted on 05 Nov 2025 02:43 PM
Re: Shift dish
How do I contact Sky? I am going around in circles trying to find a contact number.
Message posted on 05 Nov 2025 02:45 PM
Re: Shift dish
@IHB
The current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟦 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟦 online help via this link
https://www.sky.com/help
🟦 Sky Assistant 💬 should also be available via
🟦 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
