Discussion topic: Sky viewing card
Message posted on 05 Nov 2025 02:05 PM
Sky viewing card
I have an error message saying my Sky viewing card cannot be read. How can I fix this problem?
Message posted on 05 Nov 2025 03:24 PM
Re: Sky viewing card
Hi @MD49 If you have ensured that the viewing card is clean and seated properly, then you only option is to contact Sky.
Message posted on 05 Nov 2025 03:29 PM
Hi @MD49
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
