Discussion topic: Shambles Netflix
This message was authored by: Ianren
Shambles Netflix
I purchased Netflix through my q box on Sunday @11am. I don't get the activation screen and have spent 5 hrs talking to different call handles (who are clearly reading a script) first call cop out wait a couple of hours and I will call you back! No return call..2nd cop out we need to wait 24hrs ring back tomorrow 3rd cop out it's your password we need to reset it ( but the same password works on my app) 4th cop out I will transfer you to Netflix (I don't have a Netflix account it's through sky. Last cop out we will remove it!!! I want to use Netflix but sky clearly need better customer services. What a waste of my time and effort!!!
Re: Shambles Netflix
Hi @Ianren
Assume you are using the following procedure?
https://www.sky.com/help/articles/apps-on-sky-q-and-glass-using-netflix
Avatar for Ianren
I am... just no activation screen
Hi @Ianren
Exactly what happens when you select a Netflix Show?
  1. Press Home on your Sky Q remote then scroll to On Demand
  2. Scroll to Netflix and select any Netflix show
  3. Follow the on-screen instructions
Avatar for Ianren
I get sign in or join now. That's it . Apart from privacy and help. Which don't help. 🤦‍♂️ I have tried signing in with email and password and it's saying no account found
Hi @Ianren
Have you checked your Account in your Q box (My Sky at the bottom of the Home menu)?
Just to make sure that Netflix or Ultimate TV is shown in your Account.
Avatar for Ianren
Yes mate tried all that..
