3
This discussion topic has been answered Discussion topic: Set a reminder from tv guide ?
This message was authored by: DNTANNER
Hi. How can I set a "reminder" from the tv guide ? I don't want to record the program just a reminder message on screen before it starts. Thanks DT
This message was authored by: lettice Answer
Re: Set a reminder from tv guide ?
Ther has never been a reminder function on SkyQ, like the previous Sky+ had.
@DNTANNER
BTW Other features never implemented include Slow motion & Bookmarks in Recordings and the BBC Red Button Text service
As you are new to Q, I do recommend exploring the Help Section (from the bottome of the main menu on the box) which has various articles & videos
If you haven't already done so, I strongly recommend setting up your most channels as Favourites as this helps navigation (only a single key press for 1-9) and the ability to see them together in the TV Guide (although you need to select facourites or scroll up from the main guide)
N.B. Favourites have to be st up on each box.
Avatar for DNTANNER
Thanks...working on favs now.
Answered - Go to Answer
