Discussion topic: Sending equipment back
This message was authored by: Stace2
I haven't had a returns label to send my equipment back
Re: Sending equipment back
@Stace2
If you’ve successfully cancelled your subscription Sky should send out returns packaging near the end of the cancellation period, [14 days for Broadband hub and 31 days for Sky Q box(es)], to the address that the subscription was registered at.
You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
https://www.sky.com/help/articles/return-tv-broadband
If you haven’t anything suitable contact Sky again and ask if they’ll re-send. Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
Note: If you’ve moved across to Sky Glass or Stream the packaging is sent out later (5-6 weeks) in case you change your mind.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Stace2
I've have the box to return th equipment but not the returns label
@Stace2
You should be able to print labels from the link on the earlier post.
@Stace2 if you follow the link in @Daniel0210 post the one above yours the link when followed will show where to print a label
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
