5
This discussion topic has been answered Discussion topic: Second/third sky mini box
This message was authored by: Helly28
Does anyone know how much an additional sky mini box would be? We have Sky Q and a mini box but need a second mini box for a bedroom.
Second question - will Sky Glass work with an existing Sky Q box for a soon to be built extension or does it work independently?
Thank you!
Re: Second/third sky mini box
Thank you!
Hi @Helly28
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription.  Minis will require approx £50 upfront charge each.
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Subject to the above limits Sky Q minis can be used completely independently of the main Q box and the same or different program or recording can be viewed on each Q box. Even if viewing the same content it is completely independent and can be viewed at the same or different point.
Minis can do all the features same as the main Q box and can set or delete recordings on the main Q box hard drive. There is one single storage area on the main Q box with no profiles and no indication of which Q box has set a recording. (Unlike Sky+HD Multiroom which has independent storage and planners).
It should also be remembered that minis cannot view UHD recordings or content.
You cannot have Sky Glass and Sky Q at the same account address.
@Helly28
You can't mix Sky Q and Glass. It's one or the other.
Typically an up-front fee of £49, with no extra monthly cost where Multiscreen is already in place.
Can't be done: Glass/Stream replaces Q at an address.  Sky won't permit two platforms on one account.
Thank you!
Hi @Helly28
@Helly28  You can't have both Q and glass/stream it's one or the other
mini boxes are loaned to customer at £50 each non refundable
Avatar for Helly28
Level 0 icon
Thank you everyone. Thats really helpful!
