This discussion topic has been answered Discussion topic: Second multi box has few channels
Message posted on 23 Dec 2023 07:48 PM
Sky Q downstairs work fine
upstairs multi second box works but has very little channels working
no sports of film channels
Message posted on 23 Dec 2023 07:53 PM
Presuming the mini box upstairs was obtained legitimately from Sky… try rebooting the main Sky Q box first, then when that's up and running again do the same with the mini box.
~ press the 🏠 button
Message posted on 23 Dec 2023 08:48 PM
Re: Second multi box has few channels
Thanks for the idea but still only have very little channels
Message posted on 23 Dec 2023 08:55 PM
What are you seeing when you try to watch a sports or Cinema channel on the mini box?
