Discussion topic: Second Q box freezing live tv
This message was authored by: Bexx33
Live tv continuously freezing on all channels on our second Q box. Recordings play but gets stuck if you fast forward or rewind.
Main box seems okay but has frozen on the odd occasion.
Any fixes?
Re: Second Q box freezing live tv
Any fixes?
Hi @Bexx33
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Failing all this you may need a Sky Q WiFi booster to aid connectivity.
Avatar for Bexx33
Thank you @oldfella. I'll try these and see how I get on.
