Discussion topic: Screen going black
Message posted on 05 Oct 2023 09:14 AM
Screen going black
Morning,
My screen is going black when we select a channel, the tv guide works fine, we just can't watch anything!
Is there a known problem?
Many thanks
Kate
Message posted on 05 Oct 2023 09:55 AM
Re: Screen going black
@KateS1mo wrote:
Morning,
Many thanks
Kate
Hi @KateS1mo
Have you tried rebooting your Q box
Message posted on 05 Oct 2023 09:59 AM
Hi
Thank you for your response I have tried rebooting it several times. The picture will be there for a couple of second and then the screen goes black again,.
Message posted on 05 Oct 2023 10:12 AM - last edited: 05 Oct 2023 10:12 AM
@KateS1mo wrote:
Hi
Hi @KateS1mo
Make sure that the HDMI lead between the Q box and the TV is correctly located.
If you still have the issue try another HDMI lead if you have one.
Message posted on 16 Dec 2023 09:30 AM
Did you get this resolved? As mine keeps doing this now.
I thought it was my tv at first but my firestick works absolutely fine and never goes black.
Message posted on 16 Aug 2024 10:56 PM
I had this issue. I worked out it was actually when the fire stick and sky box are plugged into the TV. To resolve it short term if you unplug your TV's power lead and plug it back in Sky will stop going black. Another way have the fire stick unplugged when you power up the tv
