Discussion topic: Screen freezes when unused
Message posted on 18 Aug 2023 10:50 AM
I have an issue where my box/screen picture freezes when I don't use the box for approximately a 24-hour period.
When I turn the box back on, I can hear the correct, live volume of the channel it was left on, but the screen is frozen at some previous point in time.
I've called Sky twice and they don't seem to have an answer, and this is the second Sky Q box this has been happening on. It's happening every time
Message posted on 18 Aug 2023 10:54 AM
Re: Screen freezes when unused
Hi @Cider1977
