Discussion topic: Says problem connecting to broadband
Message posted on 26 Feb 2026 07:33 PM
Can watch any apps or multi room as it says there's a problem connecting to my broadband, even though my broadband is working
Message posted on 26 Feb 2026 07:39 PM
Re: Says problem connecting to broadband
@Marina1901 This doesn't sound like a Sky Go PC/Mobile app related issue as it dpoesn't host aps. Do you actually have Sky Q?
Message posted on 26 Feb 2026 07:42 PM
I have sky Q. It says network connection isn't working but I don't understand why.
Message posted on 27 Feb 2026 11:11 AM
Hi @Marina1901
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
