Discussion topic: Issue with Sky Minibox
This message was authored by: Jayne94
Hello,
I have an issue with my sky MiniBox,  it keeps freezing live TV and also screen flickers when watching anything on the TV.  Please can you help.
Re: Issue with Sky Minibox
@Jayne94 wrote:
Hello,
@Jayne94 Have you tried rebooting your main Q box ie
then
reboot your mini
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Rosenthistle
I have had the same problem and if I'm being honest resetting and doing everything people are saying don't really work ( for me anyway) what did work if you can is hard wire your mini boxes into the sky booster box (white one) after a reset and a few hours of running not one flicker or judder
Avatar for Jayne94
Thanks, yes tried rebooting and every trouble shooting item on the list.  Eventually I have received a new Mini Box and the problem is not sorted.  Thank you so much for your help.
Hi @Jayne94
Certainly looks like a connectivity issue rather than a fault with the mini.
Have you carried out a Network reset on the mini box?
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max white router then you need to connect the WPS to the main Q box.
