Discussion topic: Says I need to upgrade subscription
This message was authored by: Stevieg1000
So basically I can't download anything on demand or watch Apps with my subscription including Paramount Plus etc. I have all the relevant subscriptions and it has always worked previously but suddenly it's saying I don't have the relevant subscriptions which is obviously incorrect.
Avatar for Stevieg1000
Level 0 icon
Re: Says I need to upgrade subscription
FYI I have tried restarting the hub and SkyQ box and followed all the online guides to try and rectify this but nothing has resolved the issue.
@Stevieg1000
Can we clarify ~ do you have the HD add on? If not please try changing the default download preference from HD to SD in
Main Menu > Settings > Setup > Preferences
If you do have the HD add on or the above does not fix the issue post again on this thread so we can potentially escalate your post to Sky. Sky will then try to refresh the viewing card which sometimes needs a couple of attempts. This link explains more: https://www.sky.com/help/articles/call-to-upgrade-downloading-on-demand#q-help-articles
Level 0 icon
I've actually just phoned Sky and they've resolved the issue quickly by resending the signal to my Sky box. Apologies, probably should have rung them before posting on here. Thanks for your help anyway.
