Discussion topic: Satellite signal
This message was authored by: Eileenkennedy
Satellite signal
Having trouble with satellite signal
Re: Satellite signal
Hi @Eileenkennedy
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
@Eileenkennedy
If a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company who deal directly with their approved engineers.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
