Discussion topic: Satellite signal
Message posted on 24 Dec 2023 03:47 PM
Satellite signal
Sky box is saying I have no satelite sigmal and nothing is loading. Its connected to the wifi and i have restarted it and what not and still nothing. Nothing is loading, no programss, apps or tv guides.
Message posted on 24 Dec 2023 03:59 PM
Re: Satellite signal
Hi @Kiieran Do you have your own dish (may need a Sky engineer to realign it) or a communal dish (you need to contact your management company). Obviously check the cable to ensure that they are not damaged and connected properly.
Message posted on 24 Dec 2023 04:19 PM
Hey there, thanks for your reply. Don't think it is the dish as we have numerous other boxes in the house and they are all working fine. Just mine in my bedroom which isn't working. Very frustrating!
Message posted on 24 Dec 2023 05:17 PM
@Kiieran if its just yours Have you tried rebooting your main Q box ie
then
the mini box in your room
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
