Discussion topic: Satellite signal problems
Message posted on 17 Jul 2023 02:04 PM
Some channels won't work due to the channels being affected by a problem with the satellite signal
Message posted on 17 Jul 2023 02:05 PM
Re: Satellite signal problems
@Chow+mein
Have a look at this link
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
If that doesn’t help you may have to contact Sky to arrange an engineer to check your dish alignment.
Message posted on 17 Jul 2023 02:06 PM
@Chow+mein If you're getting a No Satellite signal issue try these steps. https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-live-tv/no-satellite-signal/articl...
When you get to the end it should let you book an engineer.
