Discussion topic: Satellite Dish
Message posted on 05 Apr 2024 06:19 PM
Satellite Dish
I'm not able to have a satellite dish on my property is there cant chance this product I listed still work with a SKY Q/SKY +HD Box I don't want a sky glass or a sky stream I wanna stick to the original.
Message posted on 05 Apr 2024 06:24 PM
Re: Satellite Dish
Your post is a little confusing but suffice to say a satellite dish is required for Sky Q and Sky+. They are delivered via the dish.
Message posted on 05 Apr 2024 06:25 PM
Re: Satellite Dish
Yes I recently moved houses and in my new property, it does not allow me to have a satellite dish would this Product
One For All SV9215 Flat Indoor TV Aerial.. Allow me To continue watching sky Q
Message posted on 05 Apr 2024 06:26 PM - last edited: 05 Apr 2024 06:29 PM
Re: Satellite Dish
Hi @Harley_rice
Unfortunately SKY Q (& SKY HD) need a dish.
The only time you don't need one specifically on your apartment/house is if there is a Dish feeding a communal system (such as an apartment block or for some housing schemes)
Message posted on 05 Apr 2024 06:27 PM
Re: Satellite Dish
@Harley_rice wrote:
would this Product
Afraid not @Harley_rice
Message posted on 05 Apr 2024 06:29 PM
Re: Satellite Dish
So there is no possible way off me getting SKY Q is there a indoor satellite dish that I can open a window and let it get the channels?
Message posted on 05 Apr 2024 06:31 PM
Re: Satellite Dish
no - Satellite signals are very weak & you need direct line of site of the Satellites
If they do not allow dishes on the property it might be worth enquiring whether they have provided a communal system for residents
Message posted on 05 Apr 2024 06:33 PM
Re: Satellite Dish
I could try could you send some links through eBay it's worth giving it a go you know.
Message posted on 05 Apr 2024 06:35 PM
Re: Satellite Dish
It will not work without a proper Sky supplied satellite dish or a communal dish supplied through your landlord or management company.
Message posted on 05 Apr 2024 06:36 PM
Re: Satellite Dish
Sorry a communal system is not device you can get from stores or ebay - it is a significant cost of cabling and electronics - normally used for apartment blocks providing feeds to each apartment, but occasionally for some modern housing estates
Message posted on 05 Apr 2024 07:20 PM
Re: Satellite Dish
@Harley_rice You seem to be intent on ignoring the advice provided. You need a dish located outside the property, it will not & can not work indoors.
Message posted on 06 Apr 2024 08:58 AM - last edited: 06 Apr 2024 09:02 AM
Re: Satellite Dish
'Portable' satellite television dishes do exist for situations such as mobile homes, but are essentially entirely impractical for domestic use, particularly indoors where the likelihood is there's no line-of-sight to the broadcast satellite orbital location anyway.
Any 'aerial' you see advertised is for digital terrestrial television ('Freeview') broadcasting from a local mast and absolutely cannot be used to receive Sky.
