Discussion topic: Satalight signal
This message was authored by: Claudia+givans
Satalight signal
Good evening I'm having issues with my sky and it's telling me I have no satellite signal but it was working fine before
Thank you
Re: Satalight signal
@Claudia+givans
May be connected with recent poor weather. Take a look at the troubleshooting on the appropriate section of this link. .
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
You may then need to contact Sky and arrange for an engineer to check the alignment of your dish.
This message was authored by: Terence3
No satalight
When I try to access SKY Q, It shows a message: :Technical fault?. I tried several times to book an engineer to come and fix it, but the the telephone number (removed) doesn't exist.
Moderator note: Removed contact details.
rRe: Satalight signal
Same here. No sat Alight and no answer when I try to contact SKY?
They are totally unhelpful and do not show any interest in solving our problems!"
Re: rRe: Satalight signal
@Terence3
Stay on the line as long as possible and don’t hang up. An agent will eventually answer.
