Discussion topic: SKYQ Multi room mini box not connecting
Message posted on 10 Dec 2024 01:42 PM
The final hurdle i cant get over to setup my new box is that the mini box apparently cant connect to my main skyq box? My mini box is connected to WIFI so can't understand how or why the two two boxs wont connect. Before you ask, yes they are both switched on 🙂
Any one had the same issue?
Message posted on 10 Dec 2024 03:39 PM
Re: SKYQ Multi room mini box not connecting
Hi @BrettG83
Reboot the mini as above.
