Discussion topic: SKY mini box issues
This message was authored by: JD2502
SKY mini box issues
My Sky mini box is very delayed when watching recorded programmes. Specifically, fast forwarding and rewinding, there's a lag when using these functions and incredibly hard to stop it once in motion. Mini box must be at least 6 years old if not older.  I've reset it numerous times, but I'm not sure what else to try. Any suggestions or a number to speak to the tech dept?  Thanks
Re: SKY mini box issues
@JD2502
Try a reboot of the main Sky Q box first, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Avatar for JD2502
Thanks for this @Daniel0210 I'll give it a try and hopefully things will be back to normal.
Avatar for JD2502
Sadly, the reboot didn't work.
