2
This discussion topic has been answered Discussion topic: SKY TV APPS
This message was authored by: maryannbeer
SKY TV APPS
I am having problem loading the Sky TV Apps. I get app not available try later when I try to get into Netflix Prime Disney STV Paramount. ITVX is excruciatingly slow also. This has been happening for a few days. I have reset TV a few times but does not fix the problem. Anyone else had this. I've tried contacting Sky but can't get passed the bot !!
This message was authored by: Quoman7 Answer
Re: SKY TV APPS
Hi @maryannbeer Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Re: SKY TV APPS
Avatar for maryannbeer
Level 2 icon
Re: SKY TV APPS
Thanks for reply
Thats my usual thing to do everytime there's an issue And lately there have been a few.. Sometimes have to do it few times before kicks in.
The odd thing is I have multi room and issues are only on the one TV. How odd is that.?
