Discussion topic: SKY Q mini box intermittent network connection
This message was authored by: googs
I have a main SKY 2TB box and two mini boxes but one of the mini boxes loses network connection intermittently.  I have checked wifi access in the room, where the mini box is, it is good.
Has someone else had this issue and what is the solution?
Re: SKY Q mini box intermittent network connection
Who provides your internet?  (As the Q may not be using your Wifi)
Avatar for googs
I am with BT and have been with them for over 10 years.
Ok, then your Wifi is not used for the Q boxes to connect to each other.
They create their own 5GHz network on ch 36 - ensure your BT router is not using the same space as they will interfere.
You may need to call Sky to get a booster to extend the signal.
Avatar for googs
Thanks, I will call SKY and request a booster
