Discussion topic: SKY Q and Hd
Message posted on 10 Aug 2024 06:50 AM
SKY Q and Hd
Hi I am switching over from Sky Hd to Sky Q as lost all my Sky channels.
Do I need a Hd add on subscription to continue watching them Sky channels In sd on my Sky q ? Or record them and also catch up.
Message posted on 10 Aug 2024 08:29 AM
Re: SKY Q and Hd
No, you don't need a HD sub for SD material.
Message posted on 10 Aug 2024 08:31 AM
Re: SKY Q and Hd
Sorry what I mean is sd channels still available on Sky Q?
Message posted on 10 Aug 2024 09:39 AM - last edited: 10 Aug 2024 09:40 AM
Re: SKY Q and Hd
@Topsy wrote:Sorry what I mean is sd channels still available on Sky Q?
Yes they are.
However they are quite far down the EPG in most cases or being removed as more and more channels switch to HD only, following the BBC example.
Message posted on 10 Aug 2024 10:00 AM - last edited: 10 Aug 2024 10:04 AM
Re: SKY Q and Hd
The BBC is now only availble in HD but this is FTA and does not need the HD add on
The SKY channels that are changing are not ceasing in SD just changing transmission method which means the old SD boxes can't view them . They are availble and can be watched on SKY Q
BTW You may,also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
P.P.S. you don;t necessarily need to move to SKY Q but could get a second hand HD box
EDIT : Just read your post again - do you have a SKY HD box ?
If so you should not be loosing channels - have you lost them or just getting a message to say you will lloose them
Message posted on 10 Aug 2024 10:15 AM
Re: SKY Q and Hd
Thank you I have a sky Hd box and still lost all sky channels .
Message posted on 10 Aug 2024 10:17 AM - last edited: 10 Aug 2024 10:19 AM
Re: SKY Q and Hd
Which channels have you lost ?
Can you still get channels like Alibi & Gold
Do you have your own dish or fed by a communal system ?
Message posted on 10 Aug 2024 10:22 AM
Re: SKY Q and Hd
I have lost all sky channels that come with sky signature package so all of them . Yes my own dish they sent new viewing cards bur made no difference said they are stopping signal to sky hd boxes
Message posted on 10 Aug 2024 10:28 AM - last edited: 10 Aug 2024 10:30 AM
Re: SKY Q and Hd
Can you see the channels in the EPG
What happens when you try to watch them
Can you also confirm what happens with Alibi & Gold
They are not stopping the channels on HD boxes - as mentioned they are switching transmission type that SD boxes cant decode. They have not switched all yet AFAIK
You appear to have other problems but SKY no longer support HD boxes and are keen to switch everyone to Q or Glass/Stream but that doesn't mean you should need to switch
Message posted on 10 Aug 2024 11:18 AM
Re: SKY Q and Hd
I have no sky channels at all ans sky say that can't help unless I switch over
Message posted on 10 Aug 2024 11:30 AM
Re: SKY Q and Hd
Yes SKY may say that but we may be able to offer assistance but I really need you to answer all my last questions to give any fiurther advice
Message posted on 10 Aug 2024 11:46 AM - last edited: 10 Aug 2024 11:48 AM
Re: SKY Q and Hd
That isn't correct. The SD signal format used by antique Sky+ (SD-only) hardware is in the process of ceasing, but both SD and HD service to Sky+ HD boxes will continue for the foreseeable future.
Some Sky contact centre staff may be incentivised to cause confusion though, in order to promote switching to Sky Q.
