Discussion topic: Cant get some channels
This message was authored by: VicSi06
Our regular chanels some times come on but are glitchy & most times we can not get the channels at all.
we can not get sky sports channels at all, this is the same with comedy central & a few more
so i am now paying for a services i havent got
we have unpluged the Q box rebooted and have done everything that it has shown us through sky tv but no change
Re: Cant get some channels
@VicSi06
Any error message displayed on the screen?
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
If you're getting a message indicating a problem with your satellite signal,  work through Sky's diagnostic troubleshooting here. You'll be able to book an engineer at the end, if it doesn't resolve the issue: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-check-q
