Discussion topic: SKY Q UPDATE
This message was authored by Sheetbag This message was authored by: Sheetbag
SKY Q UPDATE
i get random small annoyances, and have tried to do a manual update.
According to settings, an update is available.
I click, and it says, UPDATING.
WAIT UNTIL FINISH, AND TURN OFF.
I do all that, and follow the rules precisely
If I go back, and check again, it still says, update available, and the same issues occur
Issues....
  • No schedule
  • Recordings for same program and series, show separately in recordings list.
Apparently this is prime, do an update stuff, but it doesn't solve it ... Or update isnt updating.
Mac
Re: SKY Q UPDATE
Issues....
  • No schedule
Hi @Sheetbag
The message does not say update available.
It says Update with the latest software.
This is the message even when it is on the latest version.
Forcing a manual update when already on the latest doesn't refresh the Software and it just does an extended reboot.
This message was authored by lettice This message was authored by: lettice
Re: SKY Q UPDATE
As above, re that message.
The current Sky Q firmware is
Q210.000.6.03L
To check which Sky box you have and it's firmware version;
  1. Press Home on your Sky Q remote.
  2. Select Settings followed by System info.
  3. Check your Hardware version and use the table below to see which type of Sky Q box you have.
All detailed in this Sky help article;
https://www.sky.com/help/articles/sky-software-updates
As for your recording problems, follow the advice here;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-recordings-and-downloads/fix-a-pro...
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
Sheetbag
Re: SKY Q UPDATE
 and then we go around in circles!
That's from clicking your link.
Mac
Re: SKY Q UPDATE
@Sheetbag  what version does your box currently have ?
Re: SKY Q UPDATE
@Sheetbag wrote:
Issues....
  • No schedule
Those are issues known by Sky to be affecting some subscribers, but this doesn't mean they are resolved by any current firmware release.  Repeatedly running the manual update process just causes the box to restart each time.
