Discussion topic: I want to extend my multiscreen to a 3rd TV
This message was authored by: Herminia
need to know wht ito do with my existing hardware , can it cope with a second minibox ?
Re: I want to extend my multiscreen to a 3rd TV
@Herminia
Any 2TB main Q box can support two Mini boxes in simultaneous use, as can the 1TB UHD/HDR box.
The original non-UHD 1TB main box can only have one Mini in use at a time.
@Herminia
To check which Sky box you have:
  1. Press Home on your Sky Q remote.
  2. Select Settings followed by System info.
  3. Check your Hardware version and use the table below to see which type of Sky Q box you have.
Hardware version number Type of Sky box Software version number HDR-capable? Upgrade available?
32B0xx Sky Q 2TB Q210.000.6.03L No Yes - you can upgrade to the latest Sky Q 2TB box.
32B1xx Sky Q 2TB Q210.000.6.03L Yes No - you're already on the latest Sky Q 2TB box.
32B2XX Sky Q 1TB UHD or Sky Q 2TB* Q210.000.6.03L Yes Check the * information below the table.
32Cxx Sky Q 1TB Q210.000.6.03L No Yes - you can upgrade to a Sky Q 1TB UHD Box
32Dxx Sky Q Mini box Q210.000.6.03L No No - you already have the latest Sky Q Mini box
*Not sure if you've got a Sky Q 1TB UHD or Sky Q 2TB box?
Check the Music section to confirm your box type:
  2. Scroll to Music then select Your music.
  3. Select Play your music using Airplay. You’ll see your box type listed (e.g. Sky Q 2TB Box2725).
