4
This discussion topic has been answered Discussion topic: SKY Q MAIN BOX
This message was authored by: Rudimental
SKY Q MAIN BOX
Does anyone know which is the newest Sky Q main box the all black one or the black with silver trim ? Cheers 👋
This message was authored by: nigea99 Answer
Re: SKY Q MAIN BOX
I'll be honest I don't know the trims
If you go to
Then
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box (the latest)
https://www.sky.com/help/articles/check-which-sky-q-box
Re: SKY Q MAIN BOX
If you go to
Then
Re: SKY Q MAIN BOX
Hi @Rudimental This is th most recent 2TB SKYQ main box Click Here
Avatar for Rudimental
Re: SKY Q MAIN BOX
Cheers appreciate that 👍🏻
Re: SKY Q MAIN BOX
@Quoman7 @Rudimental not necesseraly
i'm fairly sure all 1TB boxes dont have silver trim either I know definately the original 1TB box from 2016  didnt have silver trim.
From memory only the the V1 and V2 2TB boxes had silver trim the rest are all black so the newest 2TB boxes are all black along with all of the 1TB boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
