4
This discussion topic has been answered Discussion topic: Cbeebies not working
This message was authored by: Rusty17
Cbeebies and BBC 2 have not been working for the past 2 days. All other channels are working. I've restarted the sky box and they're still not working.
Re: Cbeebies not working
@Rusty17
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
@Rusty17
Any error messages displayed?
Avatar for Rusty17
At the top of the screen it says:
This channel is currently affected by a problem with your satellite signal. For help press ?
I've pressed ? and it said to restart the box. I did this but it's still not working.
@Rusty17
Avatar for Rusty17
Thank you. I've tightened everything up at the back of the box and it's working again!
