Discussion topic: SKY Q FAULTY
This message was authored by: dimaria7
SKY Q FAULTY
When will I get a replacement sky Q box?
Re: SKY Q FAULTY
@dimaria7 wrote:
I have not received my sky Q box
Hi @dimaria7
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Re: SKY Q FAULTY
@dimaria7
In what way is it faulty? Have Sky informed you they are going to exchange it?
If they have it'll probably be via a 'doorstep box swap' whereby a courier company (usually DPD in the UK) deliver a new box and take your pre-disconnected faulty box away so remember to remove the viewing card from the old box before it disappears into the van. Also accept the power cable the courier brings in case it's a different fitting to the one you have.
Re: sky q
@dimaria7 wrote:
sky q not working
'not working' isn't a lot to advise on...
Perhaps some error messages etc.?
Re: SKY Q FAULTY
@dimaria7   Your other thread has been removed as you've already raised the issue here and have received replies.  Another thread isn't needed or helpful
Re: SKY Q FAULTY
@dimaria7
Your duplicate thread has been removed and the reply to it by @PandJ2020 moved to this one.
Its pointless making multiple threads asking the same, especially when the original thread has advice already on it.
