9
This discussion topic has been answered Discussion topic: Replacement remote control
This message was authored by: CAR-
My original remote has broken. Please send replacement.
Re: Replacement remote control
@CAR-
In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
@CAR-
This message was authored by: Lloyd60
Can you please send me a new we remote control
No, we can't. Read the post before yours.
This message was authored by: Surinderpugal
Yes I need replacement remote control
@Surinderpugal
You've posted this on the Sky Q and Sky+ boards so which do you have?
If it's Sky Q the answer is already in this thread.
This message was authored by: Smurfy
Dropped the control and it's cracked now may work and then it doesn't
@Smurfy
See my post marked as the answer.
This message was authored by: Kg51
My remote control is not working so please send me a replacement.
Hi @Kg51   Please see the Answer to this thread.
