This discussion topic has been answered Discussion topic: SKY Q Box TV does not function and sitting there with a blank screen
Message posted on 10 Feb 2026 10:37 AM
Hi,
I cannot get my TV to switch on. I have a mini Q box and have completed the suggested corrections with no luck. (Home 1,0,8,0 Home etc)
I can hear audio coming through on the GBNews channel but unable to do any changes to the settings as I cannot view the screen.
Any suggestions please?
Message posted on 10 Feb 2026 03:09 PM
Nige/Old Fella,
Thank you both for your kind assistance today.
My problem seems to have resolved itself following another dive in to the cabling accumulated behind a low wall cabinet
unit below my wall hung TV.
I found a loose cable into a digital analogue converter unit and hey presto....a lovely picture!
I am not in any way a guru on this stuff, so am unable to offer a possible reason why this would resolve the problem
but hey ho...it is resolved and I am happy.
Best wishes
Message posted on 10 Feb 2026 11:10 AM
Re: SKY Q Box TV does not function and sitting there with a blank screen
@Jockinoz wrote:
Hi,
Hi @Jockinoz
First try rebooting your television set by disconnecting the power lead for 30 seconds and then reconnecting.
Then try rebooting the mini.
Have you tried rebooting your Q box?
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Message posted on 10 Feb 2026 12:05 PM
Please may I,also, suggest unplugging the HDMI Cable at both ends and re-seating it in the sockets
Message posted on 10 Feb 2026 12:22 PM
Thank you both,
Done as suggested but with no luck.
...am currently awaiting our local tv engineer's visit...(he installed my system) - might be a while, as he is a very busy lad.
Could my Mini-Sky Q box be a suspect?
Message posted on 10 Feb 2026 12:24 PM
@Jockinoz you have probably tried this but in case you haven;t, may I suggest you, also, try a different HDMI input on the TV
Message posted on 10 Feb 2026 12:28 PM
Nige,
Thanks again.....No can do...as I have 55" LG TV fixed on the wall and am unable to lift it off to gain access.
Message posted on 10 Feb 2026 12:31 PM
@Jockinoz wrote:
Thank you both,
A possibility but as a test, perhaps, you could try taking the mini to your main TV and try it with that
Message posted on 10 Feb 2026 12:32 PM
Nige,
To be clear...my cables are run to and from, the TV/Mini Q box within the wall
Message posted on 10 Feb 2026 12:34 PM
@Jockinoz wrote:
Nige,
I gathered that might be the case but you should be able to use the same HDMI from your Main box in your mini (taking it be along side it) as a one off test
Message posted on 10 Feb 2026 12:36 PM
Nige,
I'm of an age (84..) where it is all getting too much now, so I'll pass on that advice and just await my TV man to arrive, hopefully in the next few days.
Message posted on 10 Feb 2026 12:38 PM
Nige,
My main box is upstairs...this mini Q is downstairs
Message posted on 10 Feb 2026 12:40 PM
@Jockinoz wrote:
Nige,
The minis are very portable & I was just suggesting trying it in another TV as a test but appreciate you might not wish to do that
Nige/Old Fella,
Best wishes
Message posted on 10 Feb 2026 03:36 PM
@Jockinoz wrote:
Nige/Old Fella,
Best wishes
Glad you got it sorted @Jockinoz
