7
This discussion topic has been answered Discussion topic: SKY Q BOX NOT WORKING
This message was authored by: ALON1
Sky box says it's connected to Sky Q but the screen just says: WAITING FOR TV SCHEDULE and this doesn't change. We have pressed the up/down arrows on all sky machines and it didn't work. We also turned off the sky box that is displaying this message and then back on again and still not working.
Re: SKY Q BOX NOT WORKING
Hi @ALON1
If you haven't already you need to reboot the main Q box.
Hi @ALON1
This message was authored by: Judy-fitz66
I have had continuous issues with my sky q box since it was installed. I have too continuously reboot and now the recording, pause rewind is not working. Wish I'd staying with the old box. The thoughts of having to call Sky and on hold for ages is not appealing either.
This message was authored by: Fwarford
Hey,
Did you find a solution to this? Mine has done the same, reset the box.. nothing is working including the TV remote, so I not can't reset it 🥴
This message was authored by: Rabnawazkhan
  • Its not helping i want to book qith engineers
@Rabnawazkhan
What issue are you having with your Sky Q box? Is it the same as the OP had last year?
This message was authored by: Amanda70-
This hasn't worked. The red light is on but the box is not responding in any way
@Amanda70- have you tried pressing the red light as this is the on button if it works then you may have to re-pair your remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Answered - Go to Answer
