Discussion topic: SKY BOXES NOT WORKING
This message was authored by: DoctorDread
Both of my SKY Boxes are not working, thryvare showing amber lights and not green lights.
This message was authored by: Hilary+Bugbee
Re: SKY BOXES NOT WORKING
Standard box, FTTP Connection: My box suddenly stopped connecting to the internet tonight as well for whatever reason reset button didn't work. (Pulling power cable also no fix)
However my service was still up but the hub wasn't working I removed the yellow internet cable from the back  then put it back in that fixed the issue. Might fix yours too hopefully.
What happens if you press the "light buttons" manually? Do they still not come on then? Or power off & on at the wall? I assume you must have tried that already?
Avatar for DoctorDread
Both SKY boxes NOT workjng.
I have 2 SKY boxes in separate rooms and they are both NOT WORKING
Re: Both SKY boxes NOT workjng.
hi @DoctorDread
The mini boxes get their signal from the main box, so are likely to have problems if the main box has them.
Unfortunately, just saying not working does not give us a lot to work on in terms of advice, however  may I suggest the following:
The first thing is to restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down on your mini box(es)
Both SKY Boxes not working.
How do I get in touch with SKY to get an engineer out as both my boxes not working.  I have tried everything to get them going.  I am paying a lot of money to watch SKY and I haven't been able to watch it for nearly a week now.
SKY BOXES
I have tried pressing the button but the light is still showing amber and now there is a NO Signal messsge on the TV
Re: SKY BOXES
@DoctorDread
Your latest post has been merged with your previous threads to prevent duplication of replies. No need for a new thread when it's the exact same issue being discussed.
Boxes still showing Amber lights and not working.
Sorry I'm confused. The "no signal" message on the TV only appeared AFTER you teied to turn the Sky box on by pressing its power/light button manually? It didn't appear when you first turned the TV on?
Or are you saying that pressing that button woke the TV up from standby (as it normally would when you turn a working connected sky box on) but didn't actually bring the sky box to life?
Re: Both SKY Boxes not working.
@DoctorDread  In what way are they "not working"?   Any on screen messages?  Do they switch on?
@DoctorDread
Another new thread merged into this one. There is really no point in starting multiple threads asking the same thing.
