1
This discussion topic has been answered Discussion topic: SKY Q connectivity issue
This message was authored by: Cjc5
Yesterday morning my Sky decided to disconnect from our sky broadband! I have tried reconnecting it and also switched both off and restarted them! Still won't connect, however I have full WiFi signal on all other items within the house! Appreciate any help.
Re: SKY Q connectivity issue
Hi @Cjc5
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky or Sky Max ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Hi @Cjc5
