Discussion topic: Routine failure of Sky Mini-box
This message was authored by: Grimal
My Sky Q main box works fine. The mini-box routinely fails. No amount of following online instructions makes any difference.
On speaking to Sky, they say the problem lies in the level of recorded material exceeding 70%, ( it's currently 84%, having been higher previously ) - they say that with any level in excess of 70% this more or less guarantees malfunctioning of the Minibox. Is this everyone's experience ? Not a very good advert for Sky's capacity if true ? Thanks in anticipation.
Re: Routine failure of Sky Mini-box
That's another post claiming this - it's rubbish.  (The figure given the other day was a lot lower)
Miniboxes failing to maintain a connection is either due to WiFi interference or the distance between Q boxes.
hi @Grimal
As posted by @PandJ2020 what you say Sky told you is completely false.
See if the following helps.
Reboot the mini as above.
