Discussion topic: Router SR213 compatible with Sky Q
This message was authored by: Jss236
We have two mini sky Q boxes and have just received a new sr213 router but have seen that the router only supports one mini box. Is this correct?
Re: Router SR213 compatible with Sky Q
No: that was a limitation imposed by Sky on ordering Max earlier in the rollout of the Max Hub.  It's now been removed as a limit.
They did what? What sort of madness is that?
@Chodley
Max doesn't have the now antique Q Mesh hardware support, so Sky limited ordering to some households: first only those without Q could get Max, then those with Q but only one Mini.  That ordering limitation is no longer there, and the sales system permits orders to be placed without any check for Q hardware (although a Max Hub is technically third-party as far as Q is concerned)
