Discussion topic: Restart Sky Q Box
Message posted on 30 Mar 2023 04:56 PM
Restart Sky Q Box
Is there some way to do a "proper" restart of the Sky Q box with the remote control?
By "proper" I mean the same sort of restart as switching it off at the wall socket and back on again.
Message posted on 30 Mar 2023 05:01 PM
Re: Restart Sky Q Box
The reboot does involve turning it off at the plug. Is that a problem?
HAPPY NEW YEAR
Message posted on 30 Mar 2023 05:12 PM
hi @JFM1
No, there is no option from within the GUI to perform the equivalent of a power down restart I am afraid
Message posted on 02 Sep 2023 12:29 AM
Why hasn't this simple functionality been implemented. These devices crash/lose connection on a regular basis and the only way to resolve the issue is by performing a full, ungraceful power cycle. I can't help but feel that this causes harm to the hardware/software and I expect that my SkyQ boxes will eventually shown signs of abuse in time, through no fault of my own. Sky advertised this product as "fluid viewing"... at the moment it's "Frequent unplugging,"
Message posted on 21 Nov 2023 01:14 AM
Secret:
Settings, Setup, Preferences, Change Maximum Recording to 5 or 6. It will advise the box needs to restart. Press Okay and it will then reboot.
Message posted on 27 Nov 2023 06:05 PM
Yes. I came here looking for the same reboot for the same reasons.
the other feature option is to have a way to simply force reset the WiFi connection, without having to clearl the settings and key in the network key again.
it is a constant and infuriating issue of the box losing connect ion, some time as immediately after reconnecting it!!!!
i then have to reset the network on the box keying in the long key.
Or use my router app to reboot my ASUS router. Kicking everything and everyone off the internet. All because the one stupid thing to not be able to connect is the sky Q.
God i hope virgin will run a cable down my drive!!!!!!!!
Message posted on 13 Feb 2024 04:47 PM
This is excellent, thank you.
Message posted on 13 Feb 2024 05:28 PM
@User-FriendLee wrote:Why hasn't this simple functionality been implemented. These devices crash/lose connection on a regular basis and the only way to resolve the issue is by performing a full, ungraceful power cycle. I can't help but feel that this causes harm to the hardware/software and I expect that my SkyQ boxes will eventually shown signs of abuse in time, through no fault of my own. Sky advertised this product as "fluid viewing"... at the moment it's "Frequent unplugging,"
I do like that hack above of changing the max recordings.
But I'm not sure how you would ever expect to reboot a crashed box via a remote. You can hold down the power button on the front of the box to force a reboot.
Message posted on 31 Oct 2024 03:57 PM
Thanks very much!
The sky box is in a network cupboard in the basement so this is very helpful.
Message posted on 31 Oct 2024 05:09 PM
I use a smart plug, Alexa, turn off (on) the Sky Q Plug.
Message posted on 10 Jan 2025 07:40 PM
Brilliant! Your instructions worked perfectly. Thanks.
Message posted on 28 Feb 2025 12:25 PM
Thank you thank you thank you, this is an amazing solution, what an absolute legend
Message posted on 28 Feb 2025 12:27 PM
This is another amazing solution, this and the max recording trick are spot on, thank you
