6
This discussion topic has been answered Discussion topic: Reset sky Q main box
This message was authored by: edgie700
Hi all is there a way to reset a sky Q main box , I don't just main unplugging it for a minute , thanks
Re: Reset sky Q main box
Hi @edgie700
There is a Reset Settings in the Q box hidden menu.
Hi @edgie700
Avatar for edgie700
Level 4 icon
Thanks for your reply, reason why I'm resetting it is because going through the menus it doesn't seem smooth , it's like using a smart phone with a poor processor, bit stuttery
This message was authored by: Debbie68
Good evening
I arrived home tonight and went into the livingroom and turned the TV on, I picked up the Sky remote and pressed the home button for the menu/guide to come up but nothing.
I thought maybe I need to change the battery's so I changed the battery's and still nothing, I would test the select button but I do not know where it is on the remote I also tried the button up & down on the sky q box but nothing.
Can you help me please.
Debbie Robinson
This message was authored by: Doc5907
@Debbie68 wrote:
Good evening
Debbie Robinson
Hi @Debbie68
Have a look at the below link which may be of assistance..
Sky Q manual
Sky Q 1TB UHD
LG TV
Sky Mobile
This message was authored by: Pogit
Re: Reset sky Q (main box only) via onscreen menu
Hi @edgie700  actually there is a way to reset the main sky box via onscreen menu.
 Its not really meant for this purpose but I use it for exactly this reason and I have asked for it to be made easier as its clearly possible.
I had previously used power sockets but there was an issue so I stopped using them I think it was something to do with power cuts but I now have a UPS attached to my Q box and Virgin Router
Any way to  RESTART THE MAIN Q box choose the following on screen menu options in order.
  1. Select help
  2. Select to view all help
  3. Fix a problem
  4. No satellite Signal
  5. Continue
  6. RESART NOW
Note this isn't an option on mini boxes as they don't have a direct satellite signal they get IP based content from the main box.
Hope this helps.
SkyQ 2TBv3 (32B206 - Q270.000.10.9L (5u193ht) (Ethernet) on LGUM7400, SkyQMini (32D0B2 - Q270.000.10.9L (5u193ht) (Ethernet) Virgin Media BB.
This message was authored by: timFA
thank you very easy for me to understand and do im old school not good with technical stuff thanks
Answered - Go to Answer
