Discussion topic: My screen says No Signal
Message posted on 07 Jul 2024 01:12 PM
My screen just says No Signal and I can't get any further. I have switched off and on the power but still the same
Message posted on 07 Jul 2024 01:21 PM
Re: My screen says No Signal
@Debra141
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
