1
This discussion topic has been answered Discussion topic: Requesting a callback
This message was authored by: Ryan2253
Hi how do I go about getting a callback of sky as I can't call out or send texts or use any of my data but I have signal and my bill is paid
Re: Requesting a callback
@Ryan2253
Sky won't call you back. You need to initiate contact.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: for any customer whose services are restricted due to a missed payment phone contact is unlikely to work.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
▪️I AM NOT A SKY EMPLOYEE ▪️
@Ryan2253
Answered - Go to Answer
