Discussion topic: Replacement handset
Message posted on 30 Jul 2023 03:28 PM
Replacement handset
Hi I've applied for a replacement remote.
ours started sticking and the back /batteries were getting very hot. So deemed this was unsafe to use
Message posted on 30 Jul 2023 04:35 PM
Re: Replacement handset
Have you a question? If you've completed the form to obtain a replacement you'll just have to wait for it to arrive. You could always purchase one from a larger supermarket and then you'll always have a spare.
Message posted on 02 Aug 2023 01:23 PM
My handset is having the same problems, not working, how do i request a replacement handset?
Message posted on 02 Aug 2023 01:48 PM
There is no connection when I switch on my telly
Message posted on 02 Aug 2023 02:18 PM
@FinnF
If your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some troubleshooting and then it’ll send you to a form to request a replacement (this is not available for customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It’s sometimes a bit quicker to purchase a new one from a retailer / main supermarket.
