Discussion topic: Removal of Sky q how do I get tv
Message posted on 05 Feb 2025 04:29 PM
I've removed Sky Q. I now need to plug an aerial into my TV but none of the cables seem to fit. Do I need to buy something to add to the sky cable to fit my tv?
Message posted on 05 Feb 2025 04:36 PM
Re: Removal of Sky q how do I get tv
If you have a TV aerial on your roof then you should have a standard RF (round) connector to plug into your TV.
You cannot plug the satellite dish into your TV. (The LNB won't be compatible)
Alternatively, you could purchase a FreeSat 4K box that will be.
Message posted on 05 Feb 2025 04:42 PM - last edited: 05 Feb 2025 04:44 PM
A 'sky cable' (ie from a satellite dish) will only connect into the back of a television set if the TV itself is a model which contains a satellite tuner as well as a digital terrestrial tuner.
Unfortunately even with a satellite tuner, there's still likely to be a problem with reception through a dish previously used for Sky Q.
As @PandJ2020 indicates, what you probably need is a cable coming from an aerial, not a dish.
Message posted on 05 Feb 2025 04:46 PM
The alternative solution is to acquire a Freesat 4K box, but unfortunately those aren't cheap. Earlier Freesat receivers won't work through a Q dish.
Message posted on 05 Feb 2025 05:12 PM
There used to an aerial there I'm guessing the Sky guy tidied that up when installing Q. Thanks for your help
Probably something to have considered prior to removing Q really. But yeah, one of these is less than 4 months of Sky
Message posted on 05 Feb 2025 05:15 PM
Or one with recording
Message posted on 05 Feb 2025 05:16 PM
@Angie1969 wrote:There used to an aerial there I'm guessing the Sky guy tidied that up when installing Q.
They are unlikely to have touched any RF leads.
However, you should have a plate on the wall if you have an aerial - it's a very standard RF lead to connect that plate to your TV.
For example: https://www.amazon.co.uk/kenable-Coaxial-Aerial-Black-Cable/dp/B003OSURJY
Message posted on 05 Feb 2025 05:17 PM - last edited: 05 Feb 2025 05:17 PM
https://www.argos.co.uk/product/2075868
Where do they even source a 500GB hard drive these days?
Message posted on 05 Feb 2025 07:51 PM
@TimmyBGood wrote:
@Chodley wrote:Or one with recording
SSD maybe?
Message posted on 05 Feb 2025 08:28 PM
2.5" SATA spinning rust according to YouTube.
Maybe they are salvaging them from Windows 7 laptops ; )
