Discussion topic: Remote
This message was authored by: Ellie21
Remote
Remote control voice not working
Re: Remote
@Ellie21
Check there isn't a bit of dirt/dust stuck under the button in the first instance.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Ellie21
Re: Remote
I've done that and changed batteries
Re: Remote
@Ellie21
After checking the basics, ie; re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
Avatar for Ellie21
Re: Remote
Ok thank you for your help mush appreciated
Re: Remote
@Ellie21 have you tried rebooting your router then rebooting  your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
