Discussion topic: Remote
This message was authored by: Rosie31
Remote
Back button not working
Re: Need new tv remote
See question Q26 in my Sky Plus F⋅A⋅Q
or you can purchase them in common highstreet shops ie argos, tesco etc...
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
Re: Remote
Hi @Rosie31
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple or Android device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
@Rosie31
You've posted the same on the Sky Q board so which do you have?
Re: Remote
@Rosie31
You've posted the same on the Sky+ board so which do you have?
